According to the document from the link you have 2 options to chose where to run the file from - internal or external (USB stick).
If you have selected the correct source then it might be a file error on the stick. Sometimes error messages on microcontroller based devices might be misleading as they hardly cover every particular error case.
Have you tried reading back the file to the PC?
Or use a different USB stick for a test?
If nothing else helps maybe you can split the job into smaller parts.
17-02-2014 #2
Thanks for the reply.
Yes I am running it from the stick, and have tried different sticks, but always with the same result that any file over 100mb gets near completion of loading then reports insufficient memory. I am confused as the manual says you can run direct from the stick with larger files, but when you choose this option, it still appears to need to load on to the pendant's internal memory before running. I need to find the instruction to bypass this step, or as you point out, learn how to make it as more than one part. I am reluctant to go down that route until I have ascertained beyond doubt that it is not possible run files larger than 100mb using the pendant.
JOG IT Pendant
By Leadhead in forum Marketplace DiscussionReplies: 19Last Post: 12-11-2013, 06:45 PM -
Ebay CNC Pendant help please
By Tomnewry in forum Machine Control SoftwareReplies: 4Last Post: 27-07-2013, 04:18 PM -
FOR SALE: Mach3 3 axis USB pendant
By Shinobiwan in forum Items For SaleReplies: 5Last Post: 02-02-2013, 05:42 PM -
PC gamepad as Mach3 pendant ???????
By wiatroda in forum General DiscussionReplies: 6Last Post: 02-01-2012, 11:02 AM -
CNC Pendant with 100 MPG
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 04-03-2009, 07:09 AM
