    My frame was 3mm lower at one corner after welding, I designed it to have bolt on beams to support the rails, I managed to shim those beams to within 0.5mm of each other but as Neale says there was also very slight outward twist. I therefore used epoxy to level the top surfaces prior to fitting the rails. As Neil says, if you take the epoxy route you don't have to worry excessively over the frame, as long as it's strong and stiff.
    That's what I've found anyway but it's everyone's choice to do what's best for them.
  1. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 05:29 PM
  2. Help with name of aluminium section plz
    By Fivetide in forum Milling Machines, Builds & Conversions
    Last Post: 02-12-2012, 10:01 PM
  3. Aluminium box section
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 28-10-2012, 01:13 AM
  4. spindle cross section view
    By routercnc in forum Tool & Tooling Technology
    Last Post: 05-08-2011, 12:55 AM
  5. Straightness of steel/alumunium box section
    By Jonathan in forum Linear & Rotary Motion
    Last Post: 17-09-2010, 07:53 PM
