Quote Originally Posted by Pointy View Post
Thanks for the advise and link Freddie, obviously I am very green when it comes to 3d printing. I am not sure why it would need supports though, the top piece is separate and clips in after the cables are in place, as shown in the following pic...
Name:	cable chain.png
The reason for making my own cable chain was the fact that I was struggled to find the exact size, and also the clips keep flying off as they don't slot inside like mine. It's also not my design, I just modeled what I have here already and adjusted the size to suit.
Ah - didn't spot that :-)
Designing for 3D printing takes a bit of getting used to because you can't directly print overhangs (like the lugs at the back) so you have to get the slicer to generate a support structure (a deliberately weak scaffold) that you remove afterwards or adapt the design so it isn't necessary. On the other hand you can easily print objects that would be difficult to machine (internal voids for example).
