Thread: CNC 3020 Enclosure/Upgrade
29-04-2014 #39
Thanks for the reply Eddy.
The spindle was the easiest place to mount as I am limited for space. It works fine for milling PCBs as I only really need it on for the actual milling run, and maybe the drilling if its a busy board. I am sure this design will get tweaked with use and I am thinking I could make some brackets that fit to the plate behind the spindle. Food for thought anyway.
Being a glutton for punishment I remade the IO board again from the latest PCB design (1.3). This was mainly because I have someone else who wants to make one, so I wanted to prove the latest design before releasing it. (I was still using v1.2 with a couple of bodged resistors) Well I am pleased to say that it all worked first time without issue, and hopefully that's the last time I mess with it.
I also managed to fix a couple of minor bugs in the USB controller firmware and just have to decide what to use the last button on the front panel for. Auto tool zero is something I use quite a bit so that might be an option. Again over time, I am so these will get tweaked.
Lastly, I have ordered a couple of bits of 4mm aluminium to replace the acrylic plate behind the spindle, and then I can try and get the camera mounted properly.
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
Help on building an enclosure
By thomashomer1986 in forum General ElectronicsReplies: 12Last Post: 02-02-2014, 06:38 PM -
eBay: 400x600x200 enclosure 40quid
By EddyCurrent in forum Items On eBay UKReplies: 4Last Post: 18-10-2013, 11:14 AM -
19inch Rack Enclosure - interference?
By Washout in forum General ElectronicsReplies: 12Last Post: 22-09-2012, 09:10 PM -
PCB enclosure ?
By manofgresley in forum Electronic Project BuildingReplies: 15Last Post: 10-08-2012, 11:47 AM
