  1. Hi All,
    I'm considering making a Welding Booth out of a 20ft Container, My idea is to place a 20ft container on to 2/3/4 axles to pull it around the yard this will just be a temporary solution to being able to mig/stick weld in the dry.
    The reason its mobile is because the yard I store my trailers in, I have access to 3 phase power in multiple places in the yard, the yard is a busy yard in different areas at different times of the year, so I plan to go were the quiet spots are and pull the container back out to the parking area again.
    My Questions are - Is this safe?
    - How big of an extraction fan might I need?
    - Is there anything else I might need to do?
    - Is there any other recommendations?
    - Could I make a fan?
    I look forward to hearing from you guys, Thanks in advance.
    Gavin,
    F1 Transportation & Engineering Services
    [email protected]
    We Move, Repair & Fabricate.
    Facebook - https://www.facebook.com/f1transport
    LinkedIn - https://www.linkedin.com/pub/f1-tran...ces/61/783/a06
    The extractor fan could not be so big as some would imagine. If i was doing it i would make it more local with adjustable arm and not so big funnel, there is some big lock line on eBay for this purpose. Couple that with "fan blower" , use that exact words on ebay search and you will be fine. Use "welding fume extractor" and maybe you will find cheap the hose part separately.
    One thing is that i would make it portable though. So i could use it anywhere.
ID:	15684   Click image for larger version.
ID:	15685   Click image for larger version.
  3. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
    Quote Originally Posted by F1transportationserv View Post
    Hi All,
    If you using any type of electric in a metal box make sure the box is grounded properly and the supply cables are up to the job. I take it you would need a plug and socket arrangement.
  5. #4
    I have also thought about welding fume extractor. You need super flexible/adjustable arm and good fan.
    Best is to guide the fumes straight to atmosphere. For now I just open some doors and windows or better yet work outside. Usually this light breeze is the best fume extractor for me. Angle grinder also works best outside :)
  6. #5
    Welding Tent?
    Easier to ventilate ;-) and possible to assemble around a job.
    Put welding gear and bottles on a small trailer.
  7. yes while a tent is a good idea I'm afraid the Irish weather during the winter WILL blow it away so I reckon my container may be safer :-) I am building the rest of me gear in to a 10x5x6'6 mobile workshop :-D
    Gavin,
    [email protected]
  1. shipping container workshop?
    By gavztheouch in forum Workshop & Equipment
    Last Post: 09-07-2015, 07:27 AM
  2. Replies: 1
    Last Post: 15-03-2015, 05:42 PM
  3. RFQ: RFQ TIG welding
    By Robin Hewitt in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 10:41 PM
  4. Next Industrial Revolution - 20ft Shipping Container
    By Lee Roberts in forum Machine Discussion
    Last Post: 19-09-2012, 09:40 PM
  5. TIG welding
    By Robin Hewitt in forum Welding, Brazing & Equipment
    Last Post: 03-04-2012, 10:38 PM
