Eddy, the blade is normally freely rotating and follows like a supermarket trolley castor. I think that Jazz is only referring to sharp turnsetc. for any code mods. G.
23-02-2014 #2
Check out this guy who does exactly what you want to do by the looks of it. His machines are quite light weight but adequate for the job and he makes drag knifes also.
DonekTools - YouTubeIf the nagging gets really bad......Get a bigger shed:naughty:
23-02-2014 #3
Swarfing, that's the same guy as the video we discussed on the first page. It would appear Donek have more than one youtube account.
23-02-2014 #4
I missed that link so i just checked it out and so it looks like he is into snowboarding as well.
23-02-2014 #5
Just for information. This morning I took a blunt 1/8" shank 30 degree engraving cutter, ground a new point slightly offset to the centreline - don't know what the the offset was as it was only done by eye on a green wheel, but probably about 0.3mm and ground the face opposite the flat face down to form a point - I hope that makes some sense. I then used temporary tack adhesive to stick a 0.25mm A4 acetate sheet to a self healing mat, drew a cutting program for 40 of my 1/12 scale streetlamp head glazing panels, edited the spindle start out of the code in the post processor and ran the program. Result? I now have 80 lamp glasses (I ran the program twice). The cut is quite acceptable and the cutter was clearly following in the cut direction and swiveling nicely at the corners. To be fair this was a very simple shape - just a trapezium with the four corners cut back to clear any excess solder I get when building the lampheads. The first sheet I cut at about 1500mm/min and the second at 2000mm/min. I do not think the speed made any difference, but I was trying to hold each cut piece in position as I had used the "tacky" very sparingly so that there was not much adhesive to clean off. There is no noticeable "dobbing" of the corners and no alterations were made to the G code. g.
The Following User Says Thank You to GEOFFREY For This Useful Post:
24-02-2014 #6
If the blade can be held freely rotating (I had assumed it needed a dedicated motor) then the CNC3040 could be adapted easily, surely? Just don't power the spindle. If it's big enough that is.
24-02-2014 #7
RFQ: Can you quote my project?
By Sparrow Legs in forum Projects, Jobs & RequestsReplies: 3Last Post: 30-09-2013, 07:21 AM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
RFQ: Wondering if it's possible to get these CNCd and looking for a quote
By steventhebrave in forum Projects, Jobs & RequestsReplies: 7Last Post: 07-12-2010, 03:45 PM -
Does this quote seem reasonable?
By HankMcSpank in forum General DiscussionReplies: 31Last Post: 02-03-2010, 10:21 AM
