Page 1 of 3 123 LastLast
    No, this isn't the usual question about Mach3 settings for slaved twin X-axis homing.
    I'm upgrading my cnc machine to twin X-axis ballscrews on the gantry. My new home switches have arrived, and reading the Mach3 manual and around the web shows me that I can independantly home each ballscrew to straighten the gantry. All fine.
    But what I had been expecting was that you could tell Mach3 how much to back off the switch on the slave side, to tune the final position and make it perfectly square. Otherwise it would seem that you need to design some kind of micro-adjustment on the slave microswitch to fine tune the position.
    Can anyone tell me which of these options is required - I was expecting to get the switch pretty close mechanically and then fine tune the amount of back-off in software to get it dead on.
    Take the time to Get it dead on to start with then you won't have to is the best option.!! . .. . .Then if any adjustments are needed at all your into fractions of millimeters and so just tweaking the switch is plenty.
    Proximity switches are great for this has you have adjustment via the threads on the switch and altering the sensing distance if needed has well as any lateral adjustment you build into the switch.
    I can't get my head round the fact that accuracy of the machine is down to the position and sensitivity of proximity sensors or switches.
    I'm talking about repeatability I suppose, it's not so bad when there is one switch per axis but when there is a separate one for slaved motors it makes even less sense.
    This is one area where absolute encoders are far superior and there are programmable limit switches based upon encoders but quite expensive.
    Yep I agree 100% and exactly why I prefer screws connected Via belts has it's simple and accurate.! ...............Again thou it's down to usage and for machines which don't require higher accuracy or repeatabilty like routers just cutting wood, plastics etc then slaved motors are perfectly fine provided they are run within safe limits.
    Edit: Daft as this may sound then if you want better accuracy from slaved motors than using switches just use Hard stops and slowly drive upto them before setting Zero.!
    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    If you are fitting home switches, then in general terms what's the best kind? I'm looking for repeatability here, I think, and the choice seems to be some kind of mechanical switch or a proximity switch. I'm happy that I could interface either kind with whatever electronics/breakout board I eventually select. I have some slight concerns because my 3D printer uses simple little microswitches. In principle these should work OK but I've had repeatability problems with the Z axis switch as you are looking for better than 0.05mm or so and the original switch was not capable of achieving that. In the end I swapped switches around until I found one that gave better repeatability but as a result, I'd like to make sure that the new router, when it gets built, doesn't suffer this way. Could be a critical issue if you are using dual X motors when it comes to squaring/resetting, of course.
    Question is how deep are your pockets.? High repeatabilty requires high quality switches and they cost plenty. I find for general DIY then your average chinese Proximity switch are good enough with much better repeatabilty than cheap MS and even better quality MS like Honeywell's.
    Mechanical MS are ok for limits, thou I tend to use proximity for both has they are cheap enough and I just use the same 24V supply.
    Repeatability tests on YouTube, there's plenty more too.
    G0704 Home/limit proximity switch repeatability test - YouTube
    Homemade DIY CNC Series - Home Switch Repeatability - Neo7CNC.com - YouTube
    Mechanical switch repeat ability - YouTube
    These seem to be a favourite and I think it's the ones in that first video.
    http://www.ebay.co.uk/sch/i.html?_od...witch&_sacat=0
    I got some of these for my limit switches, but will probably use proximity type for home switches. (postage a bit steep if you just want one but if buying more it's a good deal, or get from China if you want better)
    http://www.ebay.co.uk/itm/Industrial...item3f09b3b24f
    You can make your own very accurate switches for very little money. These are what I use.
    Electronic home switches made easy!
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I remember this Gerry and Romani did a great write up thou he did go a bit deep with homing to Magnetic poles of Steppers.. .Lol
    There are 2 things I don't like about these switches. Magnetic pick up and 5V.
    Magnetic is Ok for wood machine etc but not milling machines or near metal for obvious reasons.
    Don't like 5v has it's susceptible to picking up electrical noise.
    Inductive proximity switches are cheap these days and work just has good I've found and can be run thru the same 24V control system used for Limits etc.
    You also have to consider switch hysteresis because that determines how much Mach3 backs off once activated.
    These switches for example have to be backed off 5mm before they reset.
    TZ-8104 Rotary Roller Lever Arm Enclosed Limit Switch | eBay
  1. Seeking some practical squaring advice.
    By Wal in forum Gantry/Router Machines & Building
    Last Post: 09-01-2014, 12:04 AM
  2. FOR SALE: AXYZ 6012 - 4mtr x 2mtr Twin Head CNC FOR SALE
    By daverowland in forum Items For Sale
    Last Post: 28-06-2013, 06:18 PM
  3. FOR SALE: 4th axis setup
    By johngoodrich in forum Items For Sale
    Last Post: 13-06-2012, 06:17 PM
  4. Twin ball screw drive on X - configuration question
    By HiltonSteve in forum Gantry/Router Machines & Building
    Last Post: 20-05-2009, 11:13 PM
  5. Twin X axis Drives
    By Hobbit in forum Gantry/Router Machines & Building
    Last Post: 20-02-2009, 08:22 AM
