Page 2 of 2 FirstFirst 12
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has a total post count of 1,743. Received thanks 297 times, giving thanks to others 11 times.
    ...and with Bezier curves so you can tweak points and directions, you can do reasonably well. I must take a look at some software my wife uses to convert bitmap drawings into vectors which then get digitised for a computer sewing machine. It seems to do better than things like Adobe Illustrator.
    Hi Bazzer here it is thanks for having a lookClick image for larger version.
Name:	big hart1.jpg
    Hope this helps, in trace bitmap I used following options
    1. Black/white
    2. corner fit 43%
    3. noise filter 10
    4. bitmap fading none
    5. apply
    seemed to come out ok, I'm not always so lucky
    Attached Files Attached Files
    hi thanks for having a look for me i have to try in my program as when i try ed to open your saved file it can up that yours it a later version than mine :-( i will try the setting thank you
  5. #15
    I've saved 2 files to dxf, heart1 is a single vector, heart2 is the bitmap tracing of your image.
    cross fingers :)
  6. #16
    I do a lot of bitmap tracing and the only way I can get a nice clean result is to either use the trace command and then node edit the resulting vectors or manually draw over a background image, drawing and tracing with vectors is nothing like drawing with a pencil, takes loads of practice.
  1. Replies: 0
    Last Post: 19-08-2013, 12:46 AM
  2. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  3. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  4. Vectric Post Processor
    By p1lts in forum General Discussion
    Last Post: 08-10-2011, 08:02 PM
