Page 2 of 2 FirstFirst 12
    ...and with Bezier curves so you can tweak points and directions, you can do reasonably well. I must take a look at some software my wife uses to convert bitmap drawings into vectors which then get digitised for a computer sewing machine. It seems to do better than things like Adobe Illustrator.
    Hi Bazzer here it is thanks for having a lookClick image for larger version.
Name:	big hart1.jpg
    Hope this helps, in trace bitmap I used following options
    1. Black/white
    2. corner fit 43%
    3. noise filter 10
    4. bitmap fading none
    5. apply
    seemed to come out ok, I'm not always so lucky
    Attached Files Attached Files
    hi thanks for having a look for me i have to try in my program as when i try ed to open your saved file it can up that yours it a later version than mine :-( i will try the setting thank you
  5. #15
    I've saved 2 files to dxf, heart1 is a single vector, heart2 is the bitmap tracing of your image.
    cross fingers :)
  6. #16
    I do a lot of bitmap tracing and the only way I can get a nice clean result is to either use the trace command and then node edit the resulting vectors or manually draw over a background image, drawing and tracing with vectors is nothing like drawing with a pencil, takes loads of practice.
  1. Replies: 0
    Last Post: 19-08-2013, 12:46 AM
  2. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  3. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  4. Vectric Post Processor
    By p1lts in forum General Discussion
    Last Post: 08-10-2011, 08:02 PM
