Have you tried changing tool size defined in HSMexpress to see what happens? You mentioned that you had changed tool size in Mach3.
23-02-2014 #2
Yes I have. In Mach 3, the tool size change doesn't affect the cut. Changing the tool size in HSMexpress changes the code accordingly.
But as the deviation from the dimensions is not constant, I can't just define a larger tool - that then messes up other areas if you know what I mean...
Mach3 and CNC3040 incorrect zero location
By RoyT in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 30-10-2013, 03:29 AM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
Portable CNC flame plasma cutting machine
By WandrinAndy in forum Machine DiscussionReplies: 0Last Post: 03-09-2013, 04:09 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Ebay 3040 issue with mach3 - incorrect scale when machining?
By Wayne Kinney in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 04-03-2012, 12:17 PM
