  1. #7
    Lives in Plymouth, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Are the errors the same in x and y on any given piece? Are you cutting a piece out of a larger piece, or just trimming edges? Missed steps would be a classic problem but would tend to give undersize work on external cuts, and probably not be consistent on x and y. Are the cuts comfortably within the capacity of the machine, so it's not a deflection/bending issue? Still thinking out loud here...
    Just reread your first post. Are these all internal shapes? Could be missing steps, in that case.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. Mach3 and CNC3040 incorrect zero location
    By RoyT in forum Artsoft Mach (3 & 4)
    Last Post: 30-10-2013, 03:29 AM
  2. Replies: 0
  3. Portable CNC flame plasma cutting machine
    By WandrinAndy in forum Machine Discussion
    Last Post: 03-09-2013, 04:09 AM
  4. Cutting 1.6mm mild steel with a CNC machine?
    Last Post: 01-05-2012, 09:56 PM
  5. Ebay 3040 issue with mach3 - incorrect scale when machining?
    By Wayne Kinney in forum Artsoft Mach (3 & 4)
    Last Post: 04-03-2012, 12:17 PM
