Hi m_c
Tar very much for letting me know you shouldn't machine wood on a mill. Themanual says that you can machine wood on it but with what you have said I willnot do that the last thing I want is to damage my machine. I will go by whatyou say having read many of your posts. Thanks again you could have saved me alot of trouble.
All the best
Suesi
24-02-2014 #2
I once cut plywood a wind turbine blade on my milling machine with a TCT router bit, long before I'd made the CNC router. Due to the potential problems from the dust I taped paper to the machine to stop the dust getting on the slides too much, then cleaned and oiled everything thoroughly afterwards. The chipload can be kept quite high - I used something like 0.2-0.3mm chipload at 2150rpm. I think it was a 1/2" cutter. The milling machine is obviously very strong compared to a router, so you can push it quite fast. Not something I would do remotely regularly though...
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Running a three phase router/mill on a generator?
By gavztheouch in forum General ElectronicsReplies: 3Last Post: 19-02-2013, 12:39 PM -
WANTED: Looking for a used axyz 4000 series cnc router
By flanagaj in forum Items WantedReplies: 0Last Post: 30-12-2011, 11:03 AM -
Router Cutters
By sfallan in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-08-2011, 09:23 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM
