Hi EddyCurrent,
Thank you for your help I thought about the extraction side of things but whatI am hearing is the cutters will not work all that well at slow speed anyway.It is a shame as I would like to have made a few little bits out of wood!
Many thanks
Suesi
25-02-2014 #2
It might be that if you used a hard wood, hard as in 'aluminium like', you may have more success, but even so I'm cutting aluminium on my pin router that's designed for wood but I find it likes a speed of about 8000 to 10000 rpm with a 6mm spiral cutter designed for aluminium.
Janka hardness test - Wikipedia, the free encyclopedia
http://workshoppages.com/WS/Misc/Woo...ness-Chart.pdfLast edited by EddyCurrent; 25-02-2014 at 11:29 AM.
25-02-2014 #3
Unless you use a very large diameter cutter you will only "chew" most timber at 4000 rpm.This is where the horses for courses bit comes in. Milling machines are generally very rigid and are designed to cut metals and harder materials, but do not usually have high speed spindles. Routers on the other hand do usually have high speed spindles and are used predominately for softer materials. If you really want to cut timber (I seem to think that your first post referred mainly to cutting metal) I think you will need to become a "dab hand" at using abrasive paper!! Good luck. G.
25-02-2014 #4
Thanks Geoffrey,
Thank you for your post. What I am hearing from you guys TCT cutters, slowspeeds and wood are far from an ideal match. I will look out for a good CNCrouter when ready for one!
If you or anyone finds a great starting source for just getting going on a CNCmill it would be very gratefully received a starting guide or pitfalls toavoid!
Many thanks
Suesi
26-02-2014 #5
25-02-2014 #6
Hi EddyCurrent,
Thank you for your thoughts, what you say makes sense. I think I will keep myeye out for a nice CNC router for future projects in wood. There seems to besome good spec ones from China to import. I had a look at your router build logamazing what a job you did. I watched the YouTube video too. I glad all thehard work turned out to be so worthwhile. I hope things go well for you.
All the best
Suesi
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Running a three phase router/mill on a generator?
By gavztheouch in forum General ElectronicsReplies: 3Last Post: 19-02-2013, 12:39 PM -
WANTED: Looking for a used axyz 4000 series cnc router
By flanagaj in forum Items WantedReplies: 0Last Post: 30-12-2011, 11:03 AM -
Router Cutters
By sfallan in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-08-2011, 09:23 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM
