25-02-2014 #10
Unless you use a very large diameter cutter you will only "chew" most timber at 4000 rpm.This is where the horses for courses bit comes in. Milling machines are generally very rigid and are designed to cut metals and harder materials, but do not usually have high speed spindles. Routers on the other hand do usually have high speed spindles and are used predominately for softer materials. If you really want to cut timber (I seem to think that your first post referred mainly to cutting metal) I think you will need to become a "dab hand" at using abrasive paper!! Good luck. G.
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Running a three phase router/mill on a generator?
By gavztheouch in forum General ElectronicsReplies: 3Last Post: 19-02-2013, 12:39 PM -
WANTED: Looking for a used axyz 4000 series cnc router
By flanagaj in forum Items WantedReplies: 0Last Post: 30-12-2011, 11:03 AM -
Router Cutters
By sfallan in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-08-2011, 09:23 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM
