	15-07-2010 #1Hi All
 Looking to move house and so everything has to go
 I have the following for sale (+ more as I remember), all is for collection from Newport in South Wales, More info/pictures on request.
 Taig 4 axis CNC Mill, comes with the following:
 - Standard motor + ER16 spindle
 - Kress 800 FME (1hp 10k - 20k rpm) spindle & mount
 - 3 inch Tilt/swivel milling vice + 2" quick release vice
 - CNC rotary table + chuck (140oz/in)
 - 35+ end mills, fly cutter and other tooling
 - full set of er16 collets
 - 3x 320 oz/in stepper motors
 - 4x MCP stepper controllers
 - 2x MCP PSU's + breakout board
 - Sieg Collant pump & resevoir & coolant (nozzles, tubing etc)
 - Diamond drag engraver
 - HP P4 pc with 19" flatscreen
 Cost was well over £3k, am looking for £2000
 Sieg C3 Mini Lathe with Sieg DRO's and Spindle speed readout
 - 3 inch chuck
 - 4 inch chuck
 - er16 collet chuck
 - Tail stock drill chuck
 - dead centre
 - live centre
 - loads of tooling (cutters (HSS & carbide), knurler etcm indexable tooling, boring bars)
 - tailstock
 - QCTP + 3 holders
 - Wood lathe set with tools, conversion stuff
 - Pen making set including mandrel, blanks, fittings, pen kits etc
 - All gears for screw-cutting
 Cost over £700, looking for £350
 Warco 918 lathe (missing rear splash guard)
 - 4 inch chuck
 - 5 inch chuck
 - face plate
 - QCTP
 - some tooling
 - Metal gears
 looking for £375
 Axminster MCB1155HD Swivel Head Metal Cutting Bandsaw
 - good condition, still on 1st blade, mostly used for aluminium
 looking for £190
 Powercraft Air compressor + tools
 - 2Hp compressor
 - air saw
 - air cutter
 - air drill
 - various paint sprayers
 - air silicone sealent dispenser
 - air sand blaster + aluminium oxide + 15KG of glass beads for blasting
 - air regulator that also takes water out of the air and auto oils tools
 - air dusters, tyre pumps etc
 - few meteres of hose
 looking for £100
 Powder coating machine (needs an air compressor as above to use)
 - Electric Powder coating machine
 - foot pedal & dispenser
 - 20KG blue gloss powder
 - 20KG grey texture powder
 - 0.5KG brown powder
 - small toaster oven for curing
 Powder boxes alone cost £100 each and the machine cost over £200 with extra bottles
 looking for £230
 Er32 Collet chuck x2 (MT3 & straight shaft) + plus full collet set (new)
 - 2-20mm collet set (19pcs)
 - 2 x collet chucks
 looking for £70
 Metal polishing machine
 - 3 mops, 3 sets of polish hardly used, powerful 300+W motor
 looking for £50
 New Soba 4" swivel Milling vice £65
 New 4" rotary table + chuck £80
 I also have lots more such as welders, power tools, bench grinders, bench sanders, pillar drills, tools for measuring, centre drills, DTI's etc
 Please PM me to discuss
 DJH
  Affordable bandsaw that's not cr@pBy garson626 in forum Tool & Tooling TechnologyReplies: 4Last Post: 13-02-2014, 12:16 AM
  eBay: large amount of machines on e bay lathes mill plus other stuffBy Dellboy in forum Items On eBay UKReplies: 0Last Post: 17-06-2012, 09:35 AM
  4x6 Metal Bandsaw ModsBy panofish in forum Machine DiscussionReplies: 1Last Post: 09-05-2012, 08:51 AM
  Multico BandsawBy newtoid1986 in forum Marketplace DiscussionReplies: 0Last Post: 13-04-2012, 09:17 PM
