Thread: Ok, so whats wrong?
25-02-2014 #6
I run PLA with a nozzle temp of around 190C although I tend to fine-tune this depending on the particular batch of filament I'm using. I don't have enormous faith in the exact temperature as I don't know how accurate my thermocouple is, but that's a reasonable starting point anyway. You should certainly get a continuous fine thread of filament coming out - anything else means poor print quality.
Definitely a problem if you can't feed filament by hand, and it sounds like nozzle not hot enough or blocked - good luck with unblocking what's in there at the moment!
I'm interested to see how you get on with the PID controller. I spent quite a lot of time tuning the parameters of mine (built into the Sprinter code) to get best warm-up time with minimum overshoot and best stabilisation. I have built a couple of hot ends with different heater power and now have two different sets of PID parameters (especially the P and I components) to get best results. I'm curious to know if the commercial PID controller has some kind of self-learning to achieve the same results.
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM -
Whats It Worth
By Jay in forum General DiscussionReplies: 3Last Post: 21-01-2012, 09:08 PM -
whats the matter!
By ptjw7uk in forum General DiscussionReplies: 18Last Post: 29-11-2009, 07:21 PM -
DP of gears, whats it all mean?
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 25-10-2009, 11:34 PM -
Safe Z Arghhhhhhhh!! Whats going on!
By AdCNC in forum Machine DiscussionReplies: 9Last Post: 18-08-2009, 05:15 PM
