    IF you have a lathe, next time make a sleeve with a hole a nice fit on your desired tap, and a nice fit in one of your bigger holes in the jig.
    As a rule i usually centre /drill & tap all @ the same setting, ie without moving the setup but you could use your dial or digital readout to do the same, after your holes are drilled put a centre in your spindle to locate in the end of your tap and everything should be square, if you have a digital readout, much more better.
    Regards
    Mike
    Good ideas thanks for the tips mike.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    ADD ME ON FACEBOOKS
  4. The Following User Says Thank You to gavztheouch For This Useful Post:
  5. #4
    Any news for this project?
  6. #5
    typed a response, then realised how old the post was... please delete this comment..
  1. New here and wanting to build a CNC laser cutter machine
    By Gravatel in forum Laser Machines & Building
    Last Post: 13-02-2014, 05:10 PM
  2. Hand held laser cutter
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 24-10-2013, 06:05 PM
  3. What wattage laser cutter question
    By Fivetide in forum Laser Machines & Building
    Last Post: 09-08-2013, 02:56 PM
  4. Laser cutter
    By John S in forum Laser Machines & Building
    Last Post: 02-06-2012, 02:16 PM
  5. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
