    Is the term Engineering avoided because it's not involved, not known or not understood?
    And no, I don't like illuminated fans, transparent side panels or furry dice!
    - Nick
    - Nick
    Not sure the point of this post.! Maybe your on the wrong forum.? . . . This is a forum for CNC and term engineered or engineering is used in just about every build and aspect of the build.
    Give us a clue to what your on about.
    Seeing this post -
    http://www.mycncuk.com/forums/millin...html#post55711
    I investigated and discovered that Hackaday is a site which promotes "Hacking" for some it's synonymous with "Engineering" - including CNC as in this case.
    Perhaps we're all Hackers?
    Or not ;-)
    My vote is that while some of these "hackers" or "makers" are very good engineers, a lot of them are "hackers".
    My favorite quote about these people:
    The Maker Movement - Re-inventing the wheel - the hard way.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I hacked and modded a CAMM-3 mill. It was quite beautiful but IMHO let down by it's crappy motor, crappy collets and crappy firmware.
    -br
    I changed all 3 and I would call the new firmware a hack and the new parts a mod
    -br
    Then I added flood coolant which I would call bling
  7. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  8. #7
    And I thought it was Dave that got magicniner going with this thread
    http://www.mycncuk.com/forums/new-me...html#post55575
  9. #8
    Life's too short to go around in circles re-inventing or Re-making anything, I prefer to do it right first time or not to bother.
  10. #9
    Sven's Avatar
    Lives in a, Netherlands. Last Activity: 07-05-2020 Has been a member for 7-8 years. Has a total post count of 46. Received thanks 4 times, giving thanks to others 0 times.
    For that to work you have to know what "right" is.
    If you are doing something new there is a lot of stuff going on where "right" is still to be determined.
    I do a lot of development on manufacturing equipment that works on a smaller scale than the machines you can buy.
    Sure, I can buy a lot of the parts off the shelf somewhere but that costs money and even worse, time.
    That is why I hack towards a working system as quickly as I can with usually parts from just the workshop or local diy store.
    All too often I found that doing it right the first time meant that I had to do it again anyway, because the underlying assumption did not work.
    For me, hacking my way to a working result and then doing it again to improve what does not work is always quicker than doing everything right the first time....
  11. #10
    Engineers use an old technique often referred to as "Design Development".
    Hacking sounds like blindly making your way in a jungle with a machete because your sat nav is broken and can no longer tell you the way, in this metaphor engineering is being properly equipped in the first place, climbing a hill and planning a route with a map & compass ;-)
    - Nick
  1. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  2. Replies: 4
    Last Post: 28-09-2012, 12:06 PM
  3. Mach3 + 2010 Screenset crashing. "Error found , Art Code: 9988"
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 11-06-2012, 02:44 PM
  4. "Racks" VS "ball screw"
  5. Replies: 1
    Last Post: 25-12-2010, 06:05 PM
