You didn't say in your first post that you had replaced the fuse several times otherwise I would had said something different.
If a fuse blows once sometimes it's bad luck, but twice indicates a problem and as others have said the last thing is to increase the fuse size. As Clive says try it with the motor disconnected. You could swap the motor from another drive, or swap the board with another board, the trouble there is you might end up with two faulty boards.
If you bought it in the UK you could probably send it back to the suppplier for testing.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
I NeeD HeLp PLease AM882 a good choise
By jpsicilia in forum Motor Drivers & ControllersReplies: 34Last Post: 16-08-2014, 10:27 PM -
Problem with AM882 drivers !..... or it could just be me !
By Buba b in forum Motor Drivers & ControllersReplies: 10Last Post: 03-04-2013, 09:28 AM -
3 axis driver...Fuses keep blowing
By dudz in forum Motor Drivers & ControllersReplies: 5Last Post: 28-01-2013, 08:05 PM -
Fuse Size
By manofgresley in forum Motor Drivers & ControllersReplies: 1Last Post: 14-09-2012, 05:54 PM
