Thread: Control Schematic Advice
06-03-2014 #16
I'm not going there, do what you want, what I'll say is, it's not normal for the numerous industrial installations I've seen. 'Isolation and immobilisation' is a subject in itself.
If the PILZ document says that and the VFD and PSU take less current then it sounds fine, the only issue I'd think about is the inductance of the 70v PSU transformer when the contacts open. This is why I used a separate contactor because it's cheaper to replace a worn out contactor than it is to replace the PILZ relay. Having said that I've just looked at your drawing and I can see the load is split over 4 separate contacts in the PILZ (2 in series then those in parallel with another 2 in series) so that might be okay provided they all open at the same time otherwise the first one to open gets to break the arc.Last edited by EddyCurrent; 06-03-2014 at 09:23 PM.
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM -
Limit switches PCB schematic verification.
By cncnoob in forum General ElectronicsReplies: 18Last Post: 25-02-2013, 09:28 PM -
Schematic anyone?
By boldford in forum General ElectronicsReplies: 3Last Post: 28-08-2012, 10:09 AM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM -
Schematic Symbol Reference
By Lee Roberts in forum General ElectronicsReplies: 1Last Post: 23-01-2008, 03:23 PM
