Thread: Control Schematic Advice
09-03-2014 #41
09-03-2014 #42
Fastlec are sometimes okay, compare prices.
Industrial Automation & Control Systems - Fastlec.co.ukSpelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
09-03-2014 #43
09-03-2014 #44
That's why I said compare prices, some things a dearer some are okay.
09-03-2014 #45Spelling mistakes are not intentional, I only seem to see them some time after I've posted
09-03-2014 #46
Lol, no mate. 24v on/off switch, reset, e-stop, limit override and feedhold buttons should all be on the machine control panel.
I added a lamp on the contactor as I've been caught out a few times at work when e-stop buttons have accidently been pressed while a machine was powered off. Then i've gone round checking guards and fuses before i've realised why there was no life in the machine when I switched it on :/
A bit like you I've been working on the control panel before the machine. I've no idea what the temps will be inside the panel during use. I didn't really have space for both fans on the bottom gland plate. I figured the one at the top should help evacuate warm air from the drivers' heatsinks, hopefully it will also prevent dust settling on top of the vent/filter during use too.
09-03-2014 #47
09-03-2014 #48
Ah ye your probably wondering why it might send me bonkers.?. . Lol . . . I'm building the machine for Si and we are putting Switches, Reset and E-stop, feedhold etc in control panel on front of machine so when I saw what looked like switches in door I thought we'd got ( Get ready for the Pun.!!) . . Crossed wires . . Lol
04-07-2015 #49
Hello,
I'm new to CNC machine, I need your help. I have difficult in understanding the limit switch and the homing switch. I prefer to seprate the homing from limiting, i have 6 limit switch and 6 inductive proximity switch, I was planning to use the 6 limit switch for limiting (2 on each axis) and use 3 of the 6 inductive switch (one on each axis) and one inductive on x' axis for auto squaring (dual drive x axis), my problem is where to connect the limit & inductive switch on the Pmdx-126 ?! On which port?! Does I need relay ?!
Appreciate your help.
Murad
05-10-2015 #50
Hi GTJim. I have been looking at the very nice wiring diagrams you have made for your router. I have actually based my diagrams on your drawings, since we have very similar setups, and I did not know so much about safety relays.
I noticed that you use a separate time delay relay for the power supply (1 to 10s). But this is not really required. The Pilz PNOZ X9 safety relay has an on-delay of approx. 200ms (manual reset) which is fine for this use. 1 to 10 s is way too long time and only results in heating up the resistor.
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM -
Limit switches PCB schematic verification.
By cncnoob in forum General ElectronicsReplies: 18Last Post: 25-02-2013, 09:28 PM -
Schematic anyone?
By boldford in forum General ElectronicsReplies: 3Last Post: 28-08-2012, 10:09 AM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM -
Schematic Symbol Reference
By Lee Roberts in forum General ElectronicsReplies: 1Last Post: 23-01-2008, 03:23 PM
