  1. #26
    Because you are supplying the VFD and 70v PSU via the PILZ relay make sure you put the fuses for them before the PILZ, that way they will also protect the PILZ relay contacts if the fuses are less than 8amps. If the fuses are greater then 8amps then if there is a fault it could wipe out the PILZ contacts as you said they were rated at 8amps max.
    Quote Originally Posted by firetrappe View Post
    Jim, i've attached a version of my 'schematic' below.
    Strictly speaking that's a 'wiring diagram' but let's not worry about that, it's a good idea using layers, Inkscape would be a free alternative to Corel Draw.
  1. Advice Needed - Control Panel
    By GTJim in forum General Electronics
    Last Post: 18-04-2013, 08:23 AM
  2. Limit switches PCB schematic verification.
    By cncnoob in forum General Electronics
    Last Post: 25-02-2013, 09:28 PM
  3. Schematic anyone?
    By boldford in forum General Electronics
    Last Post: 28-08-2012, 10:09 AM
  4. advice on upgrade to 5 axis control
    By alanb in forum General Electronics
    Last Post: 27-07-2012, 06:29 AM
  5. Schematic Symbol Reference
    Last Post: 23-01-2008, 03:23 PM
