Page 1 of 8 123 ... LastLast
    Ok well not often I'm asking for help but with this kind of electronics I'm not so savy.!
    What I want to do is build a SIMPLE test rig for moving machine AXIS around on bench with NO PC involved.
    I've got a simple setup already that is just a Drive and MPG and it works ok but hurts my wrist winding MPG more than 3hrs watching Babe Station.
    (Stuck a drill on it but that is going to kill MPG sooner or later.)
    So what I "Think" need is a step multiplier and I want to know the simplest and easist way to do this. Ideally I would like not involve Arduino's or Rasp tarts Etc just keep to simple electronics on simple bread board PCB. (Oh and cheap to build)
    That's it really and I haven't got a clue where to start so I'm relying on you Electronic Boff's.!!
    Sticking my neck out here but something like this 2MHz DDS Function Signal Generator Module Sine/Triangle/Square Wave+case | eBay I think could drive the drives for a start ..Clive
    If you want to get the soldering iron out, a 555 based circuit should do the trick...
    555 Oscillator Tutorial - The Astable Multivibrator
    Put a variable resistor in for R2 to vary the speed and maybe a switch to change the capacitor if you want more range.
    A couple of quid should get you going.
    Hi Jazz,
    What stepper driver do you use?
    The digital drive I use on my mill have a "Test Mode" ... All you need to do is flick a micro-switch on each drive. :-)
    Can't do simpler or cheaper than that !
    RNR
    The AM882 manual has this diagram, and it says
    "In order to avoid some fault operations and deviations, PUL, DIR and ENA should abide by some
    rules, shown as following diagram: "
    So will a simple controller also have to obey these 'rules' ?
    I'm no expert but I would think you should be able to turn the motor / axis with just a few volts about 12v missing the driver and the PC out altogether Found this on YouTube look as it's a hacked PC PSU, can't get much cheaper than that. Mike
    Quote Originally Posted by longy View Post
    I don't think that is what Dean is trying to achieve as it would take forever to move the axis for testing purposes.
    He need it to move quickly up and down the axis. But a good demo of the way a stepper moves. Clive
    Clive S, that's still quicker than 3hrs mind you he was watching Babe Station so his hand may have been winding the wrong crank LOL. Or for $40 would this do the job, less strain on the wrist! CNC STEPPER SERVO MOTOR STEP Pulse Generator & TESTER Pulse generator [] - $39.99 : Get Hubbed, The Art of CNC
    Now that's more like it. ..Clive
    Clive there's others that may do what he wants from $25 would Servo/Stepper Testing : Get Hubbed, The Art of CNC or this on ebay http://www.ebay.co.uk/itm/Reversible...item41765abaf1 Mike
  1. Mach Turn
    By Kai in forum CAD & CAM Software
    Last Post: 02-08-2016, 02:40 PM
  2. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 04:41 PM
  3. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  4. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
  5. LED not turn on
    By Awel in forum Motor Drivers & Controllers
    Last Post: 06-12-2011, 06:59 AM
