  1. Hi Guys
    For a last few months I've been trying to design and build illuminated CNC control panel. Yes it took a few months :/ . Finally I've managed to finish the experimental version 1.0 it and there is the result:
Name:	control panel.jpg
    Looks like a Christmas tree, but there is a method in my madness . The buttons are color coded for ease of use and to quickly find them.
    All communication is done using Arduino Leonardo- so the board emulates the keyboard - single strokes and/or combinations.
    There is the video of the first ever proper test (off line thou)
    I'll try to upload more pics soon. If you have any questions - don't hesitate :)
    Looks good, what kind of switches did you use ? could you have based it on a USB or wireless numeric keypad thus avoiding the Arduino ?
    e.g. http://www.ebay.co.uk/itm/Number-Num...item338b160591
  3. Hi Eddy
    Each button is made from 3 and 5mm thick acrylic. Top part is painted mat black and then engraved. After that the two parts are glued together. Each button presses tactile switch. Each tactile switch/button is connected to one dedicated port in arduino leaonardo. The sketch in arduino works as follow: When the button is pressed arduino detect change of the value on the input port. Dependent on what button is pressed the arduino sends a specific command to the computer. For example when START button is pressed Arduino sends code of ALT press then shortly after that the letter R, when button is released it sends command of release Key R the release ALT. Sorry but there is no way to use this ebay keypad and to avoid arduino.
    Worth mentioning that there is no need to install any software or plugins on the computer- it sees the control panel as standard USB keyboard.
    Few pics of the parts:
    Picture above shows my first acrylic back-plate which was kind of failure.
    It was pain in the neck to glue all parts together and it didn't work as i wanted to. So I've redesigned it all and instead I've cut one-piece backplate from plywood.
Name:	plywood baclplate.jpg
Name:	front panel.jpg
ID:	11763 Click image for larger version.
Name:	buttons1 engraved.jpg
ID:	11764 Click image for larger version.
ID:	11765 Click image for larger version.
ID:	11766 Click image for larger version.
ID:	11767 Click image for larger version.
    That's an awesome build. Coming from a more PC modding background I've seen a few similar projects for other controls but yours looks very nice.
  5. Quote Originally Posted by dynamis_dk View Post
    Thanks dynamis :)
    I plan to make a proper PCB instead of crude wire connections and some enclosure to accommodate control panel, keyboard and monitor.
    YYanchev's Avatar
    Location unknown. YYanchev Last Activity: Has a total post count of n/a. Referred 6721 members to the community.
    Hey. Looks great and I think will do an excellent job. I have the following question: how many keys can be programmed with the Arduino?
  1. Mach 3 control panel help
    By IanParkin in forum Artsoft Mach (3 & 4)
    Last Post: 05-09-2014, 04:05 PM
  2. Control Panel Guidance
    By GTJim in forum General Electronics
    Last Post: 03-09-2013, 08:42 PM
  3. RFQ: Aluminium Control Panel
    By m_c in forum Projects, Jobs & Requests
    Last Post: 27-04-2013, 08:46 PM
  4. Advice Needed - Control Panel
    Last Post: 18-04-2013, 08:23 AM
  5. FOR SALE: LCD Module, VGA Driver, OSD Control Panel, Inverter unused, Boxed
    Last Post: 10-12-2011, 11:36 AM
