Thread: What has gone wrong????
06-03-2014 #1
Ok as many of you will know I have been eagerly awaiting the delivery of my new plasma torch, while waiting I have been extensively testing and debugging my new DIY CNC table and it was all going very nicely.
The torch came this morning so I moved the table into my test area, connected up the ground clamp and powered the system up.
All went ok, Mach3 was happy, so I placed a bit of test metal on the table, moved to position for a test fire and triggered a quick pierce signal, no cut just a quick pierce at half power.
That went ok so i went to move the torch back to start position for a cut test, the torch would not move so i pressed the e-stop and restarted, z axis started moving and partial x axis but not Y.
Killed the plasma supply and reloaded Mach.
Now it was jumping about randomly as i turned the MPG knob on the pendant and kept throwing "e-stop requested" errors.
Thinking it might be my cheapo crap pendant, i unplugged it, turned off "run macro-pump" and disabled support for modbus/mpg, I think that was all that is needed to return to normal?
Then i reloaded Mach and tried again, now it sort of moves but the DRO's are moving like 20mm for every physical mm moved, its very jerky too.
Pressing home-all, would bring the axes to home but then back off at 1% speed or very slow at least.
It would also still throw the e-stop requested errors.
Now, having spent a lot of effort hardening the table against RF, I cant believe I have fried it with a two second pierce?
No other PC's in the area showed any sign of problem and there was no radio interference.
This was just a quick pierce at half power.
Any suggestions at all?
I'm desperate.
Cnc cutting the wrong size..
By Tomnewry in forum Machine DiscussionReplies: 17Last Post: 25-11-2016, 10:16 PM -
Ok, so whats wrong?
By Davek0974 in forum 3D Printing MachinesReplies: 32Last Post: 27-03-2014, 12:19 PM -
When Home 3D Printing goes wrong lol :)
By Fivetide in forum Machine DiscussionReplies: 0Last Post: 18-08-2013, 04:03 PM -
1605/1610 have they sent the wrong ones?
By kingcreaky in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 30-07-2013, 09:22 PM -
What i am doing wrong with mach3?? trying to config machine.
By scnc in forum Artsoft Mach (3 & 4)Replies: 39Last Post: 31-01-2013, 05:01 AM
