wanted
I need to fix my x axis as the ball nut it noisy
i have a bed consisting of 3 850mm long 250mm wide 40mm thick t-slot peices
with the screw and nut to suit 6.35 1/8 sticking out the end
i think the nut is knackered.
anyway I want to lengthen the bed IF I am taking it apart anyway if you see?
I am sure the screws are standard 16mm thick with a 5mm pitch.
the two bearing rails are i thinnk bosche or thk 38mm rails - don't need the bearings for this.
so if you happen to have say
3 bits of 1000 long 250 by 40mm t slot = isel
two 38mm rails 1000 long
a 1000mm long 16 by 5mm pitched isel screw and nut - screw pokes out an inch i think
basically all the bits to lengthen an isel fb2 from 850 to 1000 or 1200, then thats great
want good used.
can't afford new.
WANTED: Isel router wanted
By j.c.freeman in forum Items WantedReplies: 0Last Post: 29-05-2014, 12:20 PM -
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
T-slot clamping accessories
By Neale in forum Tool & Tooling TechnologyReplies: 2Last Post: 16-02-2014, 07:48 PM -
New T-slot bed!
By jcb121 in forum General DiscussionReplies: 5Last Post: 17-07-2012, 07:36 PM -
is it possible to slot the edge on a cnc?
By wyndham in forum General DiscussionReplies: 2Last Post: 21-06-2011, 12:25 AM
