    Hi All
    Does anyone know if there is a specific setting for using a diamond drag tool for engraving on Brass Plate in metric settings .
    I want to have a go at Engraving some Brass plate and Aluminium to see if its a viable process .
    The drag tool is spring loaded but I am not sure of the feed rate and depth to go to.
    I couldnt find any info regarding the settings in past posts on here.
    Pete
    I've not investigated speeds & feeds for Diamond Drag as it copes with a wide range of speeds when using a manual pantograph engraving machine, generally it will manage higher speeds than milling so just give it a go, it's definitely viable.
    Attached is a test where the lower case in the smaller text is 1mm high, I didn't set the speed, just left it as BobCad/Cam set it for a .01mm tip V bit cutter and a .1mm DOC.
    Experiment on some scrap, the diamond drag cutters are quite robust, I haven't worn one out yet ;-)
    - Nick
Name:	Fortes Fortuna Iuvat Cropped.jpg
    Cheers Nick
    I know this may sound strange But I am completely in the dark with this diamond drag ,,,,,,Do I let the spindle start up with it in or use it with out the spindle running , any help would be appreciated on this one .
    Best Regards
    Pete
    for drag engraving G. do NOT run spindle!!!
    As Geoffrey says, spindle off.
    You can experiment with the amount of spring compression to vary line definition, I had a little too much pressure in my aluminium test block but the text came out well on Titanium,
    - Nick
  1. FOR SALE: Drag engraving tool for half inch routers.
    By evildrome in forum Items For Sale
    Last Post: 29-06-2021, 09:50 AM
  2. Tool Height Setting Probe - Mach3 - solution
    By HiltonSteve in forum Tool & Tooling Technology
    Last Post: 12-11-2013, 06:23 PM
  3. Recommended Cutters / bits from eBay for specific job
    By Fivetide in forum Tool & Tooling Technology
    Last Post: 22-11-2012, 11:42 PM
  4. another tool hight setting proble :)
    By blackburn mark in forum Tool & Tooling Technology
    Last Post: 08-09-2012, 11:30 PM
  5. Help with setting up my cnc and engraving machine's
    By soyeb in forum General Discussion
    Last Post: 30-05-2011, 11:51 AM
