  1. #2
    I've not investigated speeds & feeds for Diamond Drag as it copes with a wide range of speeds when using a manual pantograph engraving machine, generally it will manage higher speeds than milling so just give it a go, it's definitely viable.
    Attached is a test where the lower case in the smaller text is 1mm high, I didn't set the speed, just left it as BobCad/Cam set it for a .01mm tip V bit cutter and a .1mm DOC.
    Experiment on some scrap, the diamond drag cutters are quite robust, I haven't worn one out yet ;-)
    - Nick
Name:	Fortes Fortuna Iuvat Cropped.jpg
  1. FOR SALE: Drag engraving tool for half inch routers.
    By evildrome in forum Items For Sale
    Last Post: 29-06-2021, 09:50 AM
  2. Tool Height Setting Probe - Mach3 - solution
    By HiltonSteve in forum Tool & Tooling Technology
    Last Post: 12-11-2013, 06:23 PM
  3. Recommended Cutters / bits from eBay for specific job
    By Fivetide in forum Tool & Tooling Technology
    Last Post: 22-11-2012, 11:42 PM
  4. another tool hight setting proble :)
    By blackburn mark in forum Tool & Tooling Technology
    Last Post: 08-09-2012, 11:30 PM
  5. Help with setting up my cnc and engraving machine's
    By soyeb in forum General Discussion
    Last Post: 30-05-2011, 11:51 AM
