Thread: Feed and speed equation
For slotting with a 4mm HSS 1 flute cutter at 4mm DOC I am seeing 18881rpm and 2333mm/min on my calculator. You are right 0.238mm chip loading.
Carbide is 24000rpm and 2471mm/min with the other parameters the same
That's with a 15mm stick out.
That's for a finishing pass - roughing would be way higher - carbide 24,000rpm and 4745mm/min
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
App calculator feed and speed windows phone
By hoezap in forum Computer SoftwareReplies: 2Last Post: 14-02-2013, 11:44 PM -
Good tooling catalogue to calculate feed and speed
By hoezap in forum Tool & Tooling TechnologyReplies: 8Last Post: 12-02-2013, 01:12 PM -
Chamfer Feed & Speed - G-Wizard?
By Tenson in forum Computer SoftwareReplies: 4Last Post: 05-02-2013, 07:01 PM
