    Results are in...
    30A Machine torch cut on 3mm steel...
    30A Hand torch cut on 3mm steel (top line only)...
    20A Hand toch cut on 1.5mm steel at a good speed...
    The same cut but showing the reverse side (top)...
    The back dross knocked off easy, there was none on the front, one side of cut was bevelled, other was straight, i think this is normal behaviour.
    SO I will be ringing the suppliers for a smaller torch more suited to 20-50A cuts than the 50-100A torch they supplied
    I have also found another user who was sent a massive torch and is now just using the hand torch.
    This seems to be the answer.
    Tried it on 3mm sheet and much better...
    Both at 35A and 1500mm/min, the dross is easily knocked off, the "good" side of the cut is nice and square and within 0.1mm of dimension too.
    It seems it just does not like thin steel??
    I have some 1/4" scrap somewhere, will try that too, but its looking more promising.
    I have a feeling that thin stuff is going to be tougher than thick stuff.
  1. RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
    By nobby in forum Projects, Jobs & Requests
    Last Post: 29-04-2014, 12:36 PM
  2. Replies: 0
  3. Portable CNC flame plasma cutting machine
    By WandrinAndy in forum Machine Discussion
    Last Post: 03-09-2013, 04:09 AM
  4. ATX cycling fault?
    By mocha in forum Power Supplies
    Last Post: 07-12-2011, 02:08 PM
  5. Hypertherm Plasma Cutting Systems
    By Hypertherm John in forum Milling Machines, Builds & Conversions
    Last Post: 04-03-2011, 02:46 PM
