    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    You might find it only has one adjusting screw. I know mine only has one, as I wanted to have it cut out a lower pressure for when using the sandblaster, however the cut-in pressure wasn't adjustable and was a consistent 2.5-3bar lower than the cut-out pressure.
    Are you definetly sure your toolchanger needs 100psi?
    Any I've looked at are usually around 80psi.
    My long term solution is a hydrovane compressor which I still need to get plumbed in, and I'd like to build some kind of control panel so I can set pressures depending on what I'm doing.
    Many thank m_c for the reply. Yes seems a lot I know butI am sure the tool changer should have a 100 PSI it has a sticker on themachine you see by the dial and I checked in the manual. If it is not obviousto me what I have when I take the plastic piece of I will post a photo. I wishI had you knowledge of building a control panel and I would not know how towork one if I had one let alone build one. I will Google hydrovane compressor.Perhaps you would keep any eye out for the photo if I get stuck!
    Many thanks
    Suesi
  1. WANTED: EMCO Lathe Tool Changer
    By Pete92 in forum Items Wanted
    Last Post: 01-10-2013, 10:27 AM
  2. What Spindle / Auto Tool Changer?
    By Chaz in forum Tool & Tooling Technology
    Last Post: 01-08-2013, 10:35 PM
  3. how to make auto tool changer on mach3
    By m.vekariya in forum Artsoft Mach (3 & 4)
    Last Post: 13-03-2013, 08:48 PM
  4. WANTED: Denford Triac with automatic tool changer
    By hugh_munculus in forum Items Wanted
    Last Post: 12-09-2012, 12:10 PM
  5. Automatic tool changer
    By amen23 in forum Tool & Tooling Technology
    Last Post: 06-01-2009, 05:56 AM
