Page 2 of 2 FirstFirst 12
    You don't need to fear using aluminium and steel. I bought a sheet of 20mm thick aluminium, some 100x50x6 aluminium box section, 50x50x3 steel box section, 50x100x3 box section, 30x6mm steel bar, 50x10mm steel bar and various small pi6ces of 3 to 6mm aluminium plate.
    The steel was cut with a small angle grinder and these disks Toolstation > Power Tool Accessories > Cutting Discs > Multi Purpose Disc
    The aluminium was rough cut with a saw like this Amazon.com: Hitachi CR13V2 10-Amp Reciprocating Saw: Home Improvement then it was cut to size on a woodworking bandsaw with a metal cutting blade.
    Welding can be done with a small machine and all other tasks with a drill press.
    So in reality you do not require a huge array of expensive tools to get the job done in house.
    Well I'll have to take another serious look at the Mech-Mate again and make a couple of calls around on pricing because really the only difference between the MDF or Corian build and steel is the cost of the material because I'm planning on a 49"x97"x6" working envelope hence the mechanics and electronics are the same irregardless of the material the machine body. I really appreciate the input and information I've received.
    You might want to look at a kit from CNCRouterParts
    A lot easier to build then a Mechmate, and still a huge improvement over your mdf machine.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I'm very seriously looking at the MechMate DIY CNC router, I'm really impressed in it's structure.
  1. Looking for some CAM advice
    By m_c in forum Dolphin
    Last Post: 15-12-2013, 10:17 PM
  2. stepper motor buzzing sound?
    By wyndham in forum General Discussion
    Last Post: 16-06-2011, 12:35 AM
  3. Clicking sound from stepper motor & stalling
    By francooz in forum Stepper & Servo Motors
    Last Post: 06-02-2011, 04:15 PM
