One might be better off in that situation measuring the supply current and voltage to the driver, then since you (should) know the resistance of the motor at low speed, the required supply current can be estimated fairly accurately by considering the rated power. Adjust the potentiometer to get that current. The supply current should be measurable accurately using a cheap meter due to the filtering effect of the DC-bus capacitor.
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
NEW MEMBER: CNC converting in Sweden
By hubben in forum New Member IntroductionsReplies: 1Last Post: 28-09-2010, 06:16 PM
