Thread: Machine Slow on Curves
Post the G-code so can have a look.
Like as been said earlier seems Linux CNC as a quirk and if the P or Q parameter isn't stated then G64 will be ignored so if Cambam is just putting out G64 then chances are your not actually in G64.?
Try this copy the G-code file then Delete any reference to G64 or G61 from the G-code file. Next in MDI type G64 P0 Q0 then run the code again.
G64 will stay inaffect because it's Modal and will now be used for the complete program and the rest of the session unless changed by G61 or G61.1
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM -
stepper speed very slow
By jonm in forum Stepper & Servo MotorsReplies: 17Last Post: 02-11-2009, 12:39 AM
