Thread: Machine Slow on Curves
09-04-2014 #24
Well you know the Old saying about "ASSumeing".!!. . . . . . Stop and go ask over at the Cambam forum and I'm sure you'll get the correct answer.
Personally I feel your not going to get what you want because like as been said this is how 99% of Cam packages output there code for 3d surfaces. Obviously linux as a problem with this and CV or again you need to go ask the Linux technical guys over at there forum but again I don't think you'll have much "Simple" joy because I've heard complaints from several experienced CNC users that Linux is rubbish at CV.
I quote "simple" because like the post Ger linked to shows there is a Planner in progress that may solve this but then I think you'll be into messing with compiling machine code and programming etc which if your not into programming isn't simple. It's also IMO why Linux CNC gets labeled with the GEEK factor and what lets Linux CNC down because the answer all too often is you have to resort to DIY programming machine code to get something fixed or working like you want it.!! . . . . . Which you shouldn't have to do this and esp for such a basic function as CV to use a CNC machine.
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM -
stepper speed very slow
By jonm in forum Stepper & Servo MotorsReplies: 17Last Post: 02-11-2009, 12:39 AM
