    Hi Welcome.
    Several problems with the chinese machines, electronics are mostly cheap rubbish and the wiring is poor quality. Depending on the which you buy the Spindles are also rubbish unless they come with the water cooled version.
    Strength wise then they are Ok-ish but again they are low spec due to low price so Linear bearings are low quality so become baggy and loose over time, obviously depending on usage determines how quickly but it doesn't take long if pushed hard.
    Also thou they use ballscrews most I've seen suffer from poor mounting of them and use either normal deep grove bearings for the Fixed end or very poor quality and fitting angular contact bearings.
    I wouldn't recommend a second hand machine unless it's had easy life or/and is cheap and you can give it a good look over.
    My honest opinion on these machines is they are Ok for learning CNC but if you want to cut accurately and with decent feeds and Depth's of cut and still have quality finish your better to spend the money on something better or building your own.
    Hope this helps.!
    Thanks for your reply, I wouldnt have a problem with building my own but would struggle as I dont have access to a workshop to make the parts.
    If the Chinese ones, arent upto scratch what other choices are there and roughly what do they cost.
  1. NEW TO CNC - Starting design and so forth
    By PSG in forum Gantry/Router Machines & Building
    Last Post: 19-03-2014, 10:30 AM
  2. BUILD LOG: starting from scratch- router 1st project
    By idefix in forum DIY Router Build Logs
    Last Post: 10-01-2014, 12:53 AM
  3. NEW MEMBER: Complete beginener starting to learn
    By johnd in forum New Member Introductions
    Last Post: 05-04-2013, 11:10 PM
  4. Need advice on starting my own machine shop.
    By newtoid1986 in forum General Discussion
    Last Post: 04-10-2011, 10:35 PM
  5. BUILD LOG: new build just starting
    By dickieto in forum DIY Router Build Logs
    Last Post: 26-12-2009, 02:49 AM
