    Clive, it sounds like a neat and tidy solution, as an alternative you could have connected a pot to the 0-10v and analogue input. I did this with my pin router but used a 10 turn pot with a scale dial to get precise speed control, not that you actually need it to be so precise. It also means you can mount it remotely if required, such as on the front of a panel.
    dial similar to these http://www.digikey.co.uk/product-sea...Q15-1t1-VQ16-c
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    dial similar to these Invalid Request
    Yes Eddy I was aware of those pots but I did a bit of research and I deemed it unnecessary to have such precise control over the speed as soon as you set the speed and start cutting I am sure it will change. I find it very easy to adjust the speed to within a couple of hundred revs. My VFD will be outside of my control box, but next to it on the wall. For me the £1.70 spent saves me keep messing with the controls on the VFD ..Clive
  2. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  3. WANTED: Chinese 1.5kw spindle/vfd
    By Philly in forum Items Wanted
    Last Post: 10-02-2013, 11:44 AM
  4. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
  5. chinese spindle cooling
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 03-08-2011, 11:19 AM
