Page 1 of 3 123 LastLast
  1. Although these pictures are very small and bad (its what i have been given) what can you say about this 1300x2500 Cnc Router machine, construction quality, etc.
    I dont know the company that makes it, the only thing I know is the worksize. And im tempted to make a trip to get it, but i really need your help and opinions.
Name:	Captura de ecrã - 2014-04-09, 02.10.58.png
Name:	Captura de ecrã - 2014-04-09, 02.11.12.png
Name:	Captura de ecrã - 2014-04-09, 02.11.43.png
    Unfortunately I do not recognise the machine at all - is is described as a Euromod? It doesn't resemble any of the ISEL machines I know of and the construction is not as per ISEL systems (it looks like it has exposed linear rails for example).
    Sorry I can't be of any help - it looks like a nice solid machine though!
    Chris
  3. The Following User Says Thank You to badgerman For This Useful Post:
    Prob an ok machine if the price is right, certainly a good starting point for modifiying/improving. To me it looks like an older chinese built machine, similer anyway. It has Hiwin profile rails and possibly rack and pinion drive on the x and y.
    The size is great as you can use full sheets of ply, which is great for hack spaces as a lot of people design projects around 8 by 4 sheets.
    I you are looking for a guide price I would guess around £1000-2000 if it doesn't work and maybe a little more if it does. You can buy these new from china for £6000 so don't pay over the odd.
    A vacuum pump may be under that black plastic which would be a bonus, but I know the chinese ones do not work very well. A good vacuum pump for this machine could set you back £1000-1500 second hand or £2500 new.
    It looks like there is no tool changer but that would also be a nice bonus if it does.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  5. The Following User Says Thank You to gavztheouch For This Useful Post:
  6. Hello!
    After some work on building a heavy duty pallet, and some mechanical issues on the trailer brakes, i have everything ready to bring the CnC to its new home!
    As soon as i have it near me, i will post pictures.
    In the meantime maybe you all can give me your opinions:
    Quote Originally Posted by gavztheouch View Post
    In your opinion which may be the major cnc working limitations of the machine? For instance will it machine 3d wood parts?
    What improvements would you give it, and how much do you think it will cost?
  7. #5
    Quote Originally Posted by shapebusters View Post
    Mechanicly There should be no limitations for the purpose it was designed for which would be mostly wood routing. It will easily handle 3D type work and anything in between. Without knowing the resolution the only area it may not perform so well in is fine engraving or detailed work.? This is due to using rack & pinion but I'd be very surprised if it couldn't do half decent job.
    Does the machine come with it's own controller.? If it does this could be the grey area and how it handles large files that 3D work produce, it could also be an area where you struggle with post processing in CAM software. Or worse still it needs dedicated Cam software.!! If your new to CNC then post processing is where the CAM software formats the outputted G-code file to suit the Controller that runs your machine. In your case you may not know or the CAM have a post processor for that machine.
    Often with older machines that have restrictive controllers or tied to dedicated software then it's easier to just retro fit with PC Software based controller like MAch3 or Linux Cnc.
    Good luck with the move.
  9. Quote Originally Posted by JAZZCNC View Post
    Hello there!
    Thank you for your quick reply.
    Im not new to CNC, but the experience i have (that you can see part on my presentation post) is more related with the working and machining, and not so with the mechanics and machine construction.
    I have worked for some years with a Gravograph IS8000XP (1.2mx0.6m), and a bigger OUPLAN cnc machine with 3mx2m. Both 2d and 3d works, using Rhinocam, and for some simple cuts the Gravograph software (really bad one...)
    So thanks again for the advices and help, hopefully tomorrow i can place here at the end of the day a new post with photos of the machine!
    Best regards from Portugal
  10. Hello everyone!
    Well as promised, here i am sharing the adventure on buying the Cnc .
    Unlike what I had been told by the brother of the seller, the machine was in a basement , with 4 steps of depth and a very small door.
    The good part was that the machine had little things that could be pointed to the seller, so that it lowered the price even more. Since he was not in Portugal (it's in Brazil ) i sended him by email the photos, showing that when the machine was storaged there, someone bented the frame of the machine. (Dont worry, using a digital level i checked the geometry of the machine , and everything was spotless!)
    These findings allowed me to negotiate the machine for 1.750 GBP, and still bring a tool cart and some extra things. Brought the computer machine , manuals, cds , and more one thing or another.
    I found the invoice and the machine was sold by a Spanish company in October 2007 , as shown in the plate that has the back .
    After solved the transportation problem and how to make / pull the machine from the basement to the trailer, we brought it to its new home!
    One of the first things i did was to remove the bented parts and straighten them.
    Then I cleaned and lubricated the entire machine, checking tightness of bolts.
ID:	12175Click image for larger version.
ID:	12176Click image for larger version.
ID:	12177Click image for larger version.
ID:	12178Click image for larger version.
ID:	12179Click image for larger version.
ID:	12180Click image for larger version.
ID:	12181Click image for larger version.
ID:	12182Click image for larger version.
    For tomorrow i will try to make it move and cut something. But i am very positive, because when dismantling some parts for the cleaning i found very little dirt and wood particles. The machine was used but very little time.
    The Photographs of the controller unit, and command - rznc 0501 are missing, but inside there is a unit similar to this one,Click image for larger version.
    I have some questions , especially regarding the 3kw spindle. Should i install new plastic tubes? In the picture you can see they are not clean, is it supposed to be?
    Does anyone have a manual? Where am i supposed to connect the two plastic tubes?
    I would like to hear your opinions about the machine, bring it on!
    What would you improve/upgraded?
    Best regards from Portugal!
  11. #8
    Looks like it was here, in a job lot I think so price is for other stuff too ? no more info unfortunately.
    (scroll down the page a bit) Fresa usados, baratos para venda
  12. The Following User Says Thank You to EddyCurrent For This Useful Post:
  13. #9
    Eddy Current that's not what the Op asked or probably wanted broadcasting.! . .
    Shapebuster: Sorry don't know the make but Like others say it looks like chinese type machine but resonably well built, thou if that is the price then it's not really worth that sort of money unless it's fully working with Tool changer and Vacuum pump pump and even then I think it's not overly cheap.
  14. The Following User Says Thank You to JAZZCNC For This Useful Post:
  15. #10
    Never mind thumbs down ! I knew it had gone, the link from there was dead, it was to give some idea of price, if you read the text in the ad it was part of a job lot.
  16. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  3. RFQ: laser or router cnc needed
    By ktc in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:08 AM
  4. RFQ: help needed to make cnc machine maybe 2-3 and will pay
    By scnc in forum Projects, Jobs & Requests
    Last Post: 22-11-2012, 12:31 AM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
