  1. #5
    Quote Originally Posted by shapebusters View Post
    In your opinion which may be the major cnc working limitations of the machine? For instance will it machine 3d wood parts?
    What improvements would you give it, and how much do you think it will cost?
    Mechanicly There should be no limitations for the purpose it was designed for which would be mostly wood routing. It will easily handle 3D type work and anything in between. Without knowing the resolution the only area it may not perform so well in is fine engraving or detailed work.? This is due to using rack & pinion but I'd be very surprised if it couldn't do half decent job.
    Does the machine come with it's own controller.? If it does this could be the grey area and how it handles large files that 3D work produce, it could also be an area where you struggle with post processing in CAM software. Or worse still it needs dedicated Cam software.!! If your new to CNC then post processing is where the CAM software formats the outputted G-code file to suit the Controller that runs your machine. In your case you may not know or the CAM have a post processor for that machine.
    Often with older machines that have restrictive controllers or tied to dedicated software then it's easier to just retro fit with PC Software based controller like MAch3 or Linux Cnc.
    Good luck with the move.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  3. RFQ: laser or router cnc needed
    By ktc in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:08 AM
  4. RFQ: help needed to make cnc machine maybe 2-3 and will pay
    By scnc in forum Projects, Jobs & Requests
    Last Post: 22-11-2012, 12:31 AM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
