  1. Quote Originally Posted by JAZZCNC View Post
    Yes that looks very much like the machine doesn't it. I noticed the weight is 1250Kg which i would say is more realistic than 750Kg. That's not overly heavy so should move it easy enough.
    Good Luck.
    Thank you for your help!
    So you keep your opinion about the purchase relating to the quality of the machine? Any special precaution to check, or do prior to the "moving"?
    Quote Originally Posted by shapebusters View Post
    Yes it's just about what thought it would be for chinese built machine, not the best in the world but more than good enough for most small wood shops.
    Nothing to add about moving the machine other than common sense lock every thing down.
    Looking at the picture your machine as Hi-win rails which are decent quality so they shouldn't be wornout looking at the condition of the machine. Condition of Rack & pinion would be my main area to look at when you have it home. This will be the weak area on this machine either because of quality or poor maintenance and setup.
    R&P wears very quickly if not setup correctly, often it's over tightened to eliminate backlash and this causes excess friction so wears the Rack. Or other way and not maintained and pinion is under engaged so wears tops of teeth away.!
    Electronicly then can't say because it's like a box of Chocolates with Chinese machines "You never know what your going to get" but often they are one area they compromise to keep costs down.? Post pictures when you have it home and settled.
    Shame your so far away Else I'd gladly come help you move it and get working.!!. . . . Thou it does like nice and Hot there so if you want to send me ticket for plane ride I may be tempted to a Bus mans holiday. .
    How about a Bus mans holiday in sunny Lincolnshire Jazz - I could pay for the diesel. G.
  5. The Following User Says Thank You to GEOFFREY For This Useful Post:
  6. Quote Originally Posted by JAZZCNC View Post
    HAhaha! You are welcome... and it was you who remembered the idea! I can also ensure you that your Busman holiday would be very well spent! Maybe you could bring your family!
    We will (and we will not!!!) expect to have difficulties or problems with the machine!
    Thank you again, and best regards from Sintra (Azenhas do Mar) Portugal!
  7. #5
    Looks a Beautiful beautiful place to live so pretty I'm tempted to buy my own Ticket thou you may find I'd I want to stay longer than few days, more like Few decades.!!
    Geoffrey: If I wasn't so busy I'd come over in a shot but unfortunatly I'm upto my neck in work so even Sinta Portugal would be a pipe dream at the moment.
    That said My daughter will soon be at Lincoln University so I'll be coming your way at some point so I'll may be drop you a line and call see you.?
  9. #6
    You are right Jazz, our fens and cold weather cannot compete with what looks like paradise, but you will always be very wellcome if you do find yourself in the area (about 35 miles south of Lincoln) when your daughter is at university. Congratulations to your daughter for getting to university - she obviously gets her brains from her mother!!! G.
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  3. RFQ: laser or router cnc needed
    By ktc in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:08 AM
  4. RFQ: help needed to make cnc machine maybe 2-3 and will pay
    By scnc in forum Projects, Jobs & Requests
    Last Post: 22-11-2012, 12:31 AM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
