  1. Hello everyone!
    Well as promised, here i am sharing the adventure on buying the Cnc .
    Unlike what I had been told by the brother of the seller, the machine was in a basement , with 4 steps of depth and a very small door.
    The good part was that the machine had little things that could be pointed to the seller, so that it lowered the price even more. Since he was not in Portugal (it's in Brazil ) i sended him by email the photos, showing that when the machine was storaged there, someone bented the frame of the machine. (Dont worry, using a digital level i checked the geometry of the machine , and everything was spotless!)
    These findings allowed me to negotiate the machine for 1.750 GBP, and still bring a tool cart and some extra things. Brought the computer machine , manuals, cds , and more one thing or another.
    I found the invoice and the machine was sold by a Spanish company in October 2007 , as shown in the plate that has the back .
    After solved the transportation problem and how to make / pull the machine from the basement to the trailer, we brought it to its new home!
    One of the first things i did was to remove the bented parts and straighten them.
    Then I cleaned and lubricated the entire machine, checking tightness of bolts.
ID:	12175Click image for larger version.
ID:	12176Click image for larger version.
ID:	12177Click image for larger version.
ID:	12178Click image for larger version.
ID:	12179Click image for larger version.
ID:	12180Click image for larger version.
ID:	12181Click image for larger version.
ID:	12182Click image for larger version.
    For tomorrow i will try to make it move and cut something. But i am very positive, because when dismantling some parts for the cleaning i found very little dirt and wood particles. The machine was used but very little time.
    The Photographs of the controller unit, and command - rznc 0501 are missing, but inside there is a unit similar to this one,Click image for larger version.
    I have some questions , especially regarding the 3kw spindle. Should i install new plastic tubes? In the picture you can see they are not clean, is it supposed to be?
    Does anyone have a manual? Where am i supposed to connect the two plastic tubes?
    I would like to hear your opinions about the machine, bring it on!
    What would you improve/upgraded?
    Best regards from Portugal!
    Quote Originally Posted by shapebusters View Post
    Yes replace the tubes they look very contaminated. Also make sure the spindle isn't blocked up, blow air thru it.
    Connect one of the tubes to a submersible water pump inside a tank of water and return the other tube back to the tank.
  3. Quote Originally Posted by JAZZCNC View Post
    OK!
    Where am i supposed to get the power from?
    Thank you for the help!
    OK!
    The last picture you showed on the previous post is the VFD ( Variable frequency Drive) this is what controls the spindle. It takes 220-240V 60hz single phase power and converts it to 3 phase variable frequency between 0hz and upto 600hz depending on the rating of the VFD and spindle. Probably 400hz. This gives you the abilty to control the speed of the Spindle.
    You can also control the VFD from the CNC controller and have the software turn on/off and set the speed. This does require other hardware called a spindle speed controller which outputs signals to the VFD.
    Your control box may or may not have this.? If you supply good quality pictures of inside then we may be able to see if you have one or not.?
  5. Quote Originally Posted by JAZZCNC View Post
    ...If you supply good quality pictures of inside then we may be able to see if you have one or not.?
    I will do this tomorrow! Thanks again.
    When i have it running i will try to do this:
    Very easy to do but the machine will need to be setup very accurately and the bed surface machined perfectly flat.
  7. Quote Originally Posted by JAZZCNC View Post
    Well the bed surface is an easy part, i usually tape glue a pvc board on the T-slots aluminium bed, and mill it in order to rectify the Zero plane.
    The part of "Setup the machine accurately" is the dark side for me. But i have to learn it.
  8. Quote Originally Posted by JAZZCNC View Post
    Here are the pictures:
ID:	12186Click image for larger version.
ID:	12187Click image for larger version.
ID:	12189Click image for larger version.
ID:	12191Click image for larger version.
ID:	12193Click image for larger version.
    I have already changed the water cooling spindle tubes. About the cooling of the spindle can i use a Computer water cooling system?
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  3. RFQ: laser or router cnc needed
    By ktc in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:08 AM
  4. RFQ: help needed to make cnc machine maybe 2-3 and will pay
    By scnc in forum Projects, Jobs & Requests
    Last Post: 22-11-2012, 12:31 AM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
