09-04-2014 #16
Hi
that sounds a good price for a machine that size, i had been bidding on similar in the UK. Do you know how heavy it is.
When your moving it, make sure it does not bend under its own weight in the middle, Also, depending on its weight, you may need some machine skates. Good luck with moving it but make sure you understand the weight. And look for purpose build lifting points/connections.
The Following User Says Thank You to george uk For This Useful Post:
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
RFQ: laser or router cnc needed
By ktc in forum Projects, Jobs & RequestsReplies: 0Last Post: 09-08-2013, 12:08 AM -
RFQ: help needed to make cnc machine maybe 2-3 and will pay
By scnc in forum Projects, Jobs & RequestsReplies: 10Last Post: 22-11-2012, 12:31 AM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM
