right, took a few days to get everything in position so i can get to work on it. I need to transfer the picture i have sofar of the electronics to post them, am picking up the extra box tomorrow. so will post picture of that. I have a number of options with power and would like to explore everyones thoughts on the options am looking at, i need to work out
1. what's possible
2. what problems each may have
3. costs
in relation to power.
as as stated above, machine is 3 phase, 3* 0.85kw yaskawa sgdb 10vd and 15vd servos plus drivers. that i definitely want to use, a 5kw or 3.4kw spindle and driver ( frenic 5000g9s ), that if possible would like to use. It also, has 2 motors to run a saw and multi ( 15 bit ) drill head mech. and an air ram attached to each to lower out of the hood. that if i can use i will, to some extent. It has a compressor ( will put KW up tomorrow ).
I have fully independant standard supply to the workshop ( 240v ac )
I am re-designing the machine to be multi use, so i can explore a number of options for electrical supply. and this is need a bit more info on the advice above, i will try post the pictures from my phone, and i still need to take a picky of one part ( additional box )., so
generator options, is it doable from a 3 phase genny, what power ( KW ) ?
conversion to single phase. would it mean totally replacing everything,
rotary converter, does this make more sense than a genny.
any opinions
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 02:30 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM
