It will be possible to run from a generator, however it will need to be sized appropriately.
Best option will be to phone a couple different generator suppliers, explain to them what you're powering, and see what they suggest.
My guess would be aim for a generator with at least twice the KVA rating of what you need in total. The big issue will be voltage dipping/surging while motors spin up/down. The main spindle shouldn't be too bad, as the VFD will ramp up to speed off load, so there's no major start-up surge. However the vacuum motors will most likely be a simple contactor control, which will most likely cause a pretty large start-up surge.
And by the time you pay for a suitable genny, that 3k to get proper 3phase will most likely appear reasonable!Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 02:30 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM
