Thread: 1:1 ratio - pulley sizes
12-04-2014 #3
Thanks irving, didn't think about teeth engagement vs. torque. I'll be using a 400W servo (1.27Nm, peak torque of 3.82Nm) with a planetary gearbox, 12:1 ratio, this will then be coupled to a shaft via pulleys and 1:1 ratio. I doubt I will ever exceed 20Nm on the drive side, but I'd rather be sure the pulley arrangement can take the maximum 45Nm just in case. Ramp up / down speeds aren't a big issue here, so bigger pulleys should be fine, I just need to google for some teeth / torque calcs.
Regards,
T.
WANTED: TG 100 Collets in various sizes
By gavztheouch in forum Items WantedReplies: 4Last Post: 28-10-2016, 02:51 PM -
AC Motor upgrade - pulley sizes
By birchy in forum Linear & Rotary MotionReplies: 7Last Post: 21-06-2013, 10:49 PM -
pulley ratios on 3 pulley axis
By Swarfing in forum Belt Drive, Pulleys & TimingReplies: 35Last Post: 21-07-2011, 12:43 AM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
