Thread: First steel diy CNC router build
the optimum bolt size is the one that gives sufficient thread. generally you need at least 3 threads. so M6 x 1 will just give you 3, M8 x 1.25 will only give 2, so M6 but you'll need more of them to withstand shear & twisting forces. What many people do is use a 3mm plate inside the box section to add thickness so a bigger dia bolt can be used, ideally welded in place..
Also if you're bolting across the box section you'll need some tubing to stop the box being crushed...Last edited by irving2008; 21-05-2014 at 06:22 PM.
The Following User Says Thank You to irving2008 For This Useful Post:
21-05-2014 #2
I used Gorilla glue to fasten a piece of 6x30 flat bar inside a 3mm thick box section and it worked great, Gorilla Glue UK | GLUES | GLUE LIST | Gorilla Glue
While I agree with Irving's post about thread sizes, I find a good method is to look at nut thickness dimensions for any bolt size and use that as a guide to how much thread depth is required.Last edited by EddyCurrent; 22-05-2014 at 09:50 PM.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
