Thread: First steel diy CNC router build
15-04-2014 #8
No not Stupid question at all.! . . . Digital drives are newer breed of drive that use advanced alogrithams and techniques for working which results in better smoother performance. Older drives used anolgue technolgy and where restricted or lacked advanced features for dealing with issues like Resonance.
Digital drives are much better for this resonance handling alone and the better drives often allow fine tuning thru software if problems do arise but in general they just give smoother running motors and often allow higher speeds.
I use my local bearing supplier but these guys seem ok Timing Pulleys and they will machine them for you at a cost.!
You want HTD 5mm pitch and 15mm. Don't go to small on the pulleys but at same time don't go to large, I use between 18-20T depending if I apply a ratio or not. 2:1 I would use 18/36T.Last edited by JAZZCNC; 15-04-2014 at 09:41 PM.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
