    Wow, that's a handy website not just for cnc!
    Couldn't find many cnc's using timing belts for synchronising axis. So I attached what I came up with.
    So the beech colored ones are P32-5M-15F (32T) and the green one is attached to stepper using P18-5M-15F (18T)
    If my calculations is right I need around 2380mm of 15mm 5mm HTD timing belt.
    A = 940mm
    B1 = B2 = R*pi = 50.93*pi = 160mm (assuming half of the belt is on the pulley)
    C1 = C2 = 430mm
    D1 = D2 = 0.5*R*pi = 0.5*25.46*pi = 40mm (assuming 1/4 of the belt is on the pulley)
    E1 = E2 = 50mm
    F = R*pi = 25.46*pi = 80mm (assuming half of the belt is on the pulley)
    So the total length: A+2*B1+2*C1+2*D1+2*E1+F = 2380mm
    The problem is that there are only 2525mm or 2000mm available from here. So I guess I will have to fiddle a bit.
    And does anyone knows where to get these rotating pulleys (purple on drawing), at least the proper name for them?
    On the side note:
    I am about to purchase ballscrews and rails from Chai, just want to make sure I have not forgotten anything:
    SBR20-700/900mm(4 supported rails+8 SBR20UU blocks)
    DFH15 profiled rails 2x400mm+4blocks
    3pcs Anti backlsh ballscrews RM1605-450/750/950mm-C7(3screws+3ballnuts+3end machining)
    +1 anti backlsh ballscrews RM1605 950mm - C7(ballnut + end machining)
    4PCS NUT HOUSINGS/BRACKESTS(Made of Steel) FOR THESE 4 BALLNUTS
    + 4 set of BK/BF12 with locknuts and circlips
    + 2pc 6.35mm*10mm flexible couplings.
    Thanks again.
  2. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
