  1. #21
    Yes, I tested everything - there is a live wire going to "R" terminal (tested with one of those screwdriver lights) and neutral to "S" terminal, as well as ground to ground. I will test it with spindle connected in next few days, but I would think that at least power LED turns on when you apply mains, it's not like I am pressing run button or anything.
    EDIT: I attached manual page that came with FVD. My pin layout is like the one in the red box. Question is, perhaps I need to connect P with Pr?
  2. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  3. BUILD LOG: Steel frame cnc router design/build
  4. 600x900 Steel welded router build
    By embraced in forum Gantry/Router Machines & Building
    Last Post: 08-10-2014, 10:55 PM
  5. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
