Thread: First steel diy CNC router build
Thanks Jonathan for your response. The question now is, what's the optimum 'aspect ratio'?
For Y axis - distance between rails 700mm, distance between rail blocks 250mm, so that's aspect ratio of 0.3571
For X axis - distance between rails 320mm, distance between rail blocks 200mm, so that's aspect ratio of 0.625
For Z axis - distance between rails 120mm, distance between rail blocks 200mm, so that's aspect ratio of 1.667
I might consider going double ballscrew design, but that's also increase in cost. I have also read that there is a possibility of racking and damaging machine, if one of the steppers stops while other one is still going. So is the gain really noticeable in relatively small machine? Isn't steel frame rigid enough to prevent racking?Last edited by ivars211; 15-04-2014 at 02:04 PM.
15-04-2014 #2
If you want to mainly cut aluminium on this machine then you really need twin ballscrews on your Y axis (X in my world). Even with using steel the gantry will still rack when cutting aluminium or harder materials. Also like Jonathan mentioned the distance between rails on your X axis is too great so either increase clearence or lower the gantry height to bring closer together.
Regards the twin ballscrews then use single motor and join them together with timing belts and pulleys. Use 10mm pitch and gear 2:1 ratio to give same resolution as 5mm pitch but at same time increase torque.
This way it's Win win you get around the racking issues give flexabilty to machine because you can fine tune with differant ratios or increase speed if required with simple pulley change.
Less electronics to go wrong and slight saving on cost's. Motors perform smoother and better due to less resonance affects and with a All steel machine resonance can affect motors quite a lot, esp if using cheap drives.! . . . . This brings me onto Drives.?
Don't buy cheap drives with a steel machine because of resonance, paying that bit more for digital drives will pay back big time in the long run. You'll get much smoother performance from motors but more the point they deal with resonance much better which will drive you crazy and give a very rough running machine if you do encounter it.!
If your dealing with Chai ask him for a price for Profiled linear rails and you may get a pleasant surprise.?Last edited by JAZZCNC; 15-04-2014 at 07:34 PM.
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
